This is the ultimate header connector set. It contains just about every type of header connector you will ever need. You get 25 each of the following connectors.
You get 100 each of the these pins for use with 22-28AWG wire.
Don’t worry if you run out, we sell filler packs for each type.
This crimping tool can be used to crimp the contacts.
This blog post has a detailed explanation of how to use this tool to make clean connections.
