Hand Moldable Plastic
Low melting point plastic useful for hand-molding prototypes
  • Hand Moldable Plastic
  • Play
  • Play
Price Part Number Size
$8.50 1/2 pound bag
$49.50 3 pound bag
$170.00 12 pound bag
This hand moldable plastic has a melting temperature of about 136-140°F (58-60°C). It is great for making one-off prototypes, quick attachments and sub-assemblies, impressions to use as a temporary mold, and more.
Watch this video to see how to mold a tool handle.
To start the process the material needs to be heated however this can be done with a variety of techniques including hot plates, soldering irons, or by put it in a cup of water and microwave the cup for a couple minutes to heat it up. Once it reaches it molten state the plastic will be easily molded and formed by hand. After cooling to room temperature (or running under cold water) it again turns rigid. It is a true thermoplastic and can thus be re-heated and formed any number of times. If heated above about 140°F it will become sticky. This is done intentionally in hot-melt glue applications.
When in the molten state you can color the plastic by adding in pigment and mix it in a mortar and pestle. The plastic cools quickly in the mortar so we have found it’s easier to use the pestle and mix it while it’s on a hot plate which keeps it molten.
Hand moldable plastic is polycaprolactone (PCL) thermoplastic. Its unique combination of properties gives it a variety of different niche applications aside from prototyping and model making.
They’re also perfect for Halloween!
Molecular Weight
80000
Melt Flow Index
80°C, 2.16kg, g/10 min 0.59, 80°C, 21.6kg, g/10 min 9.56, 190°C, 2.16kg, g/10 min 7.29
Melting Point
60-62 °C
Crystallinity, %
56
Crystallisation Temperature
27.4 °C
Glass Transition Temperature, Tg
-60 °C
Modulus , E. Mpa
1mm/min: 440, 10mm/min: 500
Flexural Modulus, E , MPa
2mm/min: nd
Hardness
Shore A: 94, Shore D: 50
Viscosity
Pa. sec, 70°C , 10/sec: 12650, Pa. sec, 100°C , 10/sec: 5780, Pa. sec, 150°C , 10/sec: 1925
Files & Attachments
Datasheet
PDS_Capa-6800_eng-6139.pdf
MSDS
msds_capa™ 6800_usa-8225.pdf
Technical Manual
Hand Moldable Plastic Technical Manual.pdf
Accessories
Add Your Project
View More
FAQ
What should I consider for disposal of this material?
Hand moldable plastic is fully biodegradable; it has good water, oil, chlorine, and solvent resistance; and has a low melting temperature.
