Gorilla Glue
The only glue tough enough to be called Gorilla!
Gorilla Glue
  • Gorilla Glue
  • Gorilla Glue
  • Gorilla Glue
  • Gorilla Glue
  • Gorilla Glue
Price Part Number Dry Color Size
$7.99 Tan 2 oz
$23.00 Tan 18 oz
$35.49 $21.29 Tan 36 oz
$5.49 $3.29 White 2 oz
Gorilla Glue is known for its industrial holding power and versatility, regardless of the substrate. Easily bonds wood, stone, metal, ceramic, foam, glass and more.
100% waterproof – does not break down when exposed to outdoor elements
Ideal for most household fixes, indoors or out
Temperature resistant – once dry, Gorilla Glue is unaffected by extreme heat or cold
Expands 3-4 times the application amount, penetrating the glued surface for a superior bond
Sandable, paintable and stainable – the invisible glue line makes for easy finishing
Clamp Time: 1-2 hours
Open Time: 5-10 minutes
Full Cure: 24 hours
Dry Color: light tan or white (see chart above)
Files & Attachments
MSDS - Tan
MSDS Gorilla Glue English June 2012.pdf
MSDS - White
MSDS Dries White English June 2012.pdf
