Fluorescent Orange Reflective Tape
Enhance visibility in low-light or night time conditions
Price Part Number Description
$7.87 25.4 mm by 1 m strip of tape with a release liner
This tape will help enhance visibility in night time or low-light conditions when a light source, such as headlights, shines on it. The material is composed of wide angle, retroreflective lenses, in the form of 50,000 glass beads per square inch, bonded to an adhesive. It works when illuminated by returning the light back toward its original source.
Fabric Scrim
94% polyester / 6 % nylon tricot knit
Adhesive
Acrylic
Daytime Color
Fluorescent red-orange
Reflected Color
White
Add your project
FAQ
What are the use and care instructions for this material?
Application Instructions:
1. Clean and dry the surface (the tape works best on smooth surfaces)
2. Remove the liner
3. Position the film and press firmly into place across the entire surface
Cutting:
Die-cutting is recommended, although it can also be hand-cut or guillotined.
Screen Printing:
Images may be printed on the surface of the tape. All inks should be continuously tested to ensure acceptable adhesion in the event of changes occurring in the manufacturing process or composition of the ink. Prior to printing, wiping the surface with a soft cloth lightly dampened with isopropyl alcohol may help ink adhesion. Printed areas will not be retroreflective.
Care Recommendation:
Damp wipe only, using warm water and mild detergent. Rinse thoroughly, dry with a soft cloth or allow to air dry.
