Flexible LED Strip - Warm White
Plug and play adhesive LED strip with connector wire and power supply
  • Flexible LED Strip - Warm White
This 5 meter long adhesive, flexible LED strip makes lighting your project easy. It includes pre-soldered connector wire and a 5A 12V power supply, meaning you can simply connect the pieces, plug it in, and be done. It features 120 SMD3528 LEDs per meter for a total of 600 LEDs per strip, meaning it’s extremely bright while maintaining low power consumption. You can cut the strip between every 3 LEDs to customize it to your desired length.
Please note that this strip is not waterproof and is meant for indoor use.
They’re also perfect for Halloween!
LED type
SMD3528
LEDs/meter
120
Voltage
12V
Power source
DC
Wattage
48W
Working current
4A
Emitting angle
120°
Lumen
3200-3500 Lm
Frequency
50-60HZ
Certification
CCC, CE, CQC, EMC, FCC, PSE, RoHS
Avg. life
50,000 hours
