This 5 meter long adhesive, flexible LED strip makes lighting your project easy. It includes pre-soldered connector wire and a 5A 12V power supply, meaning you can simply connect the pieces, plug it in, and be done. It features 120 SMD3528 LEDs per meter for a total of 600 LEDs per strip, meaning it’s extremely bright while maintaining low power consumption. You can cut the strip between every 3 LEDs to customize it to your desired length.
Please note that this strip is not waterproof and is meant for indoor use.
They’re also perfect for Halloween!
LED type |
SMD3528 |
LEDs/meter |
120 |
Voltage |
12V |
Power source |
DC |
Wattage |
48W |
Working current |
4A |
Emitting angle |
120° |
Lumen |
3200-3500 Lm |
Frequency |
50-60HZ |
Certification |
CCC, CE, CQC, EMC, FCC, PSE, RoHS |
Avg. life |
50,000 hours |
Size |
5 meter length strip, 0.8mm width, 0.5mm thick between LEDs, 2mm thick on LED |
