Eccentric Spacer 3mm Bore
The off center hole allows this to adjust V wheels
Price Part Number Type
$1.85
This is a spacer that has an off center (Eccentric) 3mm hole drilled through it. It is used to tension V wheels against MakerSlide material. You mount this in a 5mm hole. When you rotate it, it will move a V wheel mounted to it, allowing you to adjust the tension against the Makerslide rail.
Material
Stainless Steel
Files & Attachments
Technical Drawing
b18040_rev_2.pdf
CAD File (STEP)
b18040.zip
Add your project
