Eccentric Nut
This is a spacer that has an off center (eccentric) 5mm x 0.8 tapped hole through it
Eccentric Nut
Price Part Number Spacer Type
$2.49 Nut
Overview
This is a spacer that has an off center (eccentric) 5mm x 0.8mm tapped hole through it. It is used to tension V wheels against MakerSlide material. You mount this in a 7.14mm (0.281 dia.) hole. When you rotate it, it will move a V wheel mounted to it, allowing you to adjust the tension against the MakerSlide rail.
Thread Size
5mm x 0.8mm
Mount Hole
7.14mm (0.281)
Material
Stainless Steel (type 303)
Files & Attachments
Technical Drawing
b18033_rev_1.pdf
CAD File (STEP)
b18033_rev_1.zip
