Dual Bearing V-Wheel Kit, 3mm Bore
A wheel for riding on V track like MakerSlide
This is double bearing, Delrin, V-wheel. It uses (2) 623 RS bearings and a precision shim washer. It has very low runout, so it will run wobble free. The mounting is very simple with only a 3mm hole required.
An easy way to tension the wheels against the rail, is to use eccentric spacers for the wheels on one side of the carriage.
Files & Attachments
Technical Drawing (Wheel)
b17064_rev_1.pdf
Technical Drawing (Assembly)
b30067_rev_1.pdf
CAD File (STEP)
b30067.zip
Add your project
