Drag Chain
This keep your cables protected on moving parts
Drag Chain
  • Drag Chain
  • Drag Chain
  • Drag Chain
  • Drag Chain
  • Drag Chain
  • Drag Chain
  • Drag Chain
Price Part Number Type Inside Height Inside Width Qty Link Type
$3.49 Drag Chain Ends 15mm 30mm 2 Semi Open
$25.49 Drag Chain 15mm 40mm 1m Enclosed
$3.99 $2.39 Drag Chain Ends 15mm 40mm 2 Enclosed
$17.49 Drag Chain 15mm 20mm 1m Semi Open
$2.99 Drag Chain Ends 15mm 20mm 2 Semi Open
$16.49 Drag Chain 10mm 15mm 1m Hinged
Each 1 meter piece includes 2 ends. The links snap together so you can shorten or lengthen it. The ends have mounting holes.
This is drag chain or sometimes called energy chain or cable carrier. This has individual links that only swivel in one direction. Wires and cables are run in inside the links. This allows wiring to be protected when run close to moving parts It insures a minimum bend radius to protect them from fatigue.
Additional ends can also be purchased separately. This is handy if you break the standard piece into more than one length. Each 2 pack includes 1 male and 1 female end.
The hinged link type can be opened for easier post-assembly wiring changes.
PLEASE NOTE: the drag chain does not include the brackets or hardware needed to mount this to an X-Carve.
Files & Attachments
Technical Drawing (PDF)
DragChain.pdf
