Clear Acrylic Sheet - Cast
Cast sheets good for use in laser cutters
  • Clear Acrylic Sheet - Cast
Price Part Number Dimensions Thickness Material Type
$10.34 12 in × 24 in 1/8 in Extruded
$16.17 18 in × 24 in 1/8 in Extruded
$4.99 8 in × 12 in 1/8 in Extruded
$21.17 12 in × 24 in 1/4 in Extruded
$5.99 8 in × 12 in 1/8 in Cast
$10.99 12 in × 24 in 1/8 in Cast
$15.66 18 in × 24 in 1/8 in Cast
$8.99 12 in × 24 in 1/16 in Cast
$29.49 18 in × 24 in 1/4 in Cast
$19.49 12 in × 24 in 1/4 in Cast
$2.89 8 in × 12 in 1/4 in Cast
$2.99 8 in × 12 in 1/16 in Cast
$13.49 18 in × 24 in 1/16 in Cast
$4.99 8 in × 12 in 1/32 in Cast
$14.99 12 in × 24 in 1/32 in Cast
$21.99 18 in × 24 in 1/32 in Cast
$9.74 12 in × 12 in 1/4 in Cast
$7.39 8 in × 12 in 1/2 in Cast
$11.29 12 in × 12 in 1/2 in Cast
$5.99 8 in × 12 in 3/16 in Cast
$14.99 12 in × 24 in 3/16 in Cast
Acrylic is a plastic material that looks similar to glass, but is less brittle and provides better insulation. This acrylic sheet comes in both extruded, or “continuous cast” acrylic, as well as cast acrylic. Extruded acrylic is less expensive than cast acrylic, is softer, and can scratch easier. Here is a picture of what both cast and extruded bought from our store look like when laser etched.
The thicknesses listed are nominal. Here are the actual thicknesses:
  • 1/32" – .039"
  • 1/16" – .060"
  • 1/8"- .125"
  • 3/16" – .187"
  • 1/4" – .220"
  • 1/2" – .500"
Color
White
Cut Tolerance
+/- 1/8 in
Form
Transparent
Opacity
Transparent
Surface Finish
Glossy
Thickness Tolerance (1/8" and thicker)
+/- 8%
Thickness Tolerance (1/16" and thinner)
+/- 15%
