X-CARVE IS IN STOCK. SHIPS SAME BUSINESS DAY.
COVID-19 Update: Inventables is fully operational. Call us: (312) 775-7009
(M–F 9am – 5pm CST)
Clamp Set
A versatile clamping system for a 3D carver
Clamp Set
  • Clamp Set
  • Clamp Set
  • Clamp Set
  • Clamp Set
Price Part Number Type
$35.00 Clamping System
This set consists of 4 clamps, 4 threaded insert and a set of screws. The clamps are made of red oak. They are strong, but are less likely to shatter bits if they are hit. You should only need one set. The CAD file is provided so you can make your own if you damage one.
PDF Drawing
DXF File
3D Model
The clamps have an M6 threaded insert at one end. You can use the provided M6 carriage bolts to adjust the height of the clamp. This allows you to adjust the clamp so that is less likely to damage softer materials.
There is more information on this blog post
Parts List
Files & Attachments
Technical Drawing (PDF)
b25002_rev_4.pdf
CAD File (DXF)
b25002_rev_4.dxf
Assembly Instructions (PDF)
Instructions-WoodClampSet.pdf
