Free shipping on orders of $100 or more within contiguous US. Exclusions apply.
Carbide V Bit
Cut V shapes with your 3D carver or hand router
Carbide V Bit
  • Carbide V Bit
  • Carbide V Bit
  • Carbide V Bit
Price Part Number Shank Diameter Cutting Diameter Tip Angle Cutting Length
$13.99 1/4 in 1/2 in 90 Degree 0.36 in
$13.99 1/4 in 1/2 in 60 Degree 0.5 in
This is a V-shaped carbide-tipped cutter bit. This can be used to cut V shapes into material or can be used with high-end 3D carving software to do V carving. There is a 90° tip and pointier 60° tip version available.
The shank diameter is 1/4", so make sure you have a 1/4" collet.
Best for cutting
Plastic, wood, plywood, MDF
