Carbide Tip V-Bit 90 Degree - 1/4 in Cutting x 1/8 in Shank
Carbide bits for your v-carving projects
Price Part Number Cutting Diameter Shank diameter Tip Angle
$21.40 1/4 in 1/8 in 90 Degree
V-bits are great for carving very intricate, detailed designs. When used in conjunction with v-carving software, they add depth and dimension that can’t be achieved with a flat bit.
Our v-bits have an angle tolerance of +/- 1°. They do not have a flat tip tolerance.
Best for Cutting
solid wood, plastic, plywood and MDF
Angle tolerance
+/- 1°
