Camouflage Laserable Acrylic Sheet
Digital camo patterned acrylic that engraves white
Price Part Number Dimension Thickness
$6.39 8 in × 12 in 1/16 in
This 2-ply cast acrylic has a layer of digital camouflage pattern over a layer of white. The white is exposed when the sheet is engraved 0.003" (0.08mm) or deeper with a laser cutter or 3D carving machine.
Color
Brown
Color
Green
Color
White
Cut Tolerance
± 1/8 in
Effect
2 color
Effect
Patterned
Opacity
Opaque
Surface Finish
Matte non-reflective
Thickness
1/16 in
Thickness Tolerance
± .016 in
Files & Attachments
MSDS
Camo Acrylic MSDS.pdf
Add your project
