Bubinga
A dense African hardwood with red coloring
Bubinga
  • Bubinga
  • Bubinga
$8.32 $6.24 6 in × 12 in 1/8 in
Bubinga grows in equatorial Africa. The coloring ranges from pink to darker red and is frequently found with a variety of figuring from mottling to flamed, quilted and waterfall. This dense wood averages a substantial 58 lbs per cubic foot.
Because this is a natural material, the color and pattern will vary slightly from piece to piece. Please see the thickness tolerance below and note that thickness will change based on conditions like humidity.
Thinner boards take more time and labor to produce; therefore, while the 1/16" pieces are thinner, they are the same price as the 1/8" pieces.
Thickness Tolerance
+/- .04"
Dimensions
6 in × 12 in
Species
Bubinga
Type
Hardwood
