Brush-on Silicone Rubber for Mold Making
Easy to use material for making brush-on molds of almost any model
Price Part Number Material
$30.10 Silicone
This silicone rubber is self-thickening and can be applied with a brush or spatula to vertical surfaces without sagging. It cures with insignificant shrinkage to a soft, flexible rubber. It does not stick to most surfaces, minimizing surface prep time, and features an easy part 1A:1B by weight or volume mix ratio. Four thin layers are all that is required to make a stretchy, strong and durable production mold for casting wax, gypsum, concrete or resins like urethane or polyester.
Mix Ratio
Mixed Viscosity
Brushable
Specific Gravity
g/cc: 1.14
Specific Volume
cu. in./lb.: 23.5
Pot Life
20 minutes (73°F/23°C)
Cure Time
6 hours (73°F/23°C)
Color
Orange
Shore A Hardness
25
Tensile Strength
psi: 515
Elongation at Break
690%
Die B Tear Strength
pli: 102
Shrinkage
in./in.: <.001
Files & Attachments
Datasheet
Rebound_25_Brush-On.pdf
MSDS
Rebound_25 MSDS.pdf
Add your project
FAQ
Any limitations or other information that is useful to know about this material?
This product will not work with modeling clays containing sulfur under any circumstances.
Also, although not usually necessary, a release agent will make demolding easier when pouring into or over most surfaces.
Use in a properly ventilated area. Wear safety glasses, long sleeves and rubber gloves to minimize contamination risk. Wear vinyl gloves only. Latex gloves will inhibit the cure of the rubber.
