Mon - Fri: 9am - 5pm CT
Sun: 12pm - 4pm CT
Support: 312-775-7009
Blue MDF Sheet
Strong, organically dyed wood fiber panels
Blue MDF Sheet
  • Blue MDF Sheet
  • Blue MDF Sheet
$18.11 12 in × 12 in 1/4 in
$6.71 8 in × 12 in 1/4 in
Features
  • Easy to machine
  • Non-toxic
Cut tolerance
+/- 1/16"
Color
Blue
Thickness
1/4 in
Type
MDF
Files & Attachments
Data Sheet
forescolor_technical_data_sheet.pdf
