3-Axis DSP Based Digital Stepper Driver
Control your CNC with super smooth DSP control
Price Part Number Type
$289.00 $173.40 3 Axis Stepper Motor Driver
Leadshine MX3660
This 3 axis stepper driver is based on the latest DSP control technology. This allows the smoothest, quietest and coolest control of your motors. It has an integral breakout board, so everything wires directly to terminal blocks like the motors, limit switches, e-stop and even high performance DSP based spindles.
  • Power up to 3 stepper motors of NEMA 17, 23, 24, or 34
  • 200 KHz maximum frequency for each axis
  • 20 VDC – 60 VDC supply voltage
  • 1.45 – 6.0A output current per axis
  • 8 micro step settings: 1, 1/2, 1/4, 1/8, 1/10, 1/16, 1/32, 1/64
  • 8 output current settings: 1.45, 2.08, 2.72, 3.37, 4.05, 4.72, 5.35, 6.0 A
  • Damping and anti resonance
  • Individual output current & micro step settings for each axis
  • Input pulse smoothing for less jittering, higher torque, and quicker response
  • Extra low motor heating & noise
  • Extra smooth motor movement
  • Simple micro step & output current configuration via DIP switches
  • Fault output
  • 50% automatic idle current reduction
  • Works with Mach3, LinuxCNC and other programs
Files & Attachments
Datasheet (PDF)
MX3660d_V1.1.pdf
Hardware Installation Manual (PDF)
MX3660hm_V1.1.pdf
Mach3 Profile (XML)
xml file of the MX3660 for MACH3.xml.zip
