Z-Axis Adjusting Knob
752 opens
406 copies
2 comments
DIYTyler
DIYTyler
Quick project to make manual adjustments of your X-Carve Z axis much simpler.
Birch Plywood
Birch Plywood
Make shape on computer
Came up with the shape I was after using sketchup, exported to .svg using the “Sketchup to SVG” plugin and imported into Easel.
Once in easel I used the interactive tabs to move some of the tabs on top of each other effectively decreasing the total number of tabs. In the end I wanted two tabs in a location that could easily be broken off.
Carve
Carved using the X-Carve equipped with a 1/8 bit.
Sand, paint and insert nut
Remove your carved knob from the rest of the board. Sand, paint if you want to and insert the nut that is on top of the Z-Axis motor pulley….nylon down into the knob.
Dowel Turning Pin
2 minutes
Drill and countersink a small section of dowel, add to the knob so you can quickly turn the know without taking your hand off it.
Re-Install
Reinstall the nut and knob back to the top of the Z-Axis and you are done!
Watch and Learn
3 minutes
Check out our channel for more projects.
Fred Sawtelle
Nice design, and it looks to be quite useful. Question: doesn't this throw off position-tracking? In other words, if Work Zero has been set and this is then used to manually move the spindle, the code-interpreting program (Easel, UGS, whatever) will not know that Z has changed, correct?
Fred Sawtelle
DIYTyler
If you change the height manually after you set the Z height it will mess up your cut. This is really for before/after cutting to manually move the head around if you need to.
DIYTyler
