Y Axis Height Upgrade
28 opens
9 copies
2 comments
Kris Crawford
Kris Crawford
Canada
I’ve modified the original design to fit on a 2 inch piece of material
Andrew Minter
Would you by chance have any pictures of your machine after installing these? Or do you have any input on if they have caused any issue for you? I'm just trying to find out if there's any drawbacks to doing this upgrade before machining the parts. Any input would be helpful, thanks, Drew.
Andrew Minter
Kris Crawford
This allows more clearance for larger material. I'm in the process of upgrading to a Linear C beam, so I actually don't have pictures as of yet. The only drawback would be if you are using thinner materials, so you would have to put a sacrificial board on your wasteboard to boost up the height.
Kris Crawford
