My first project:
A laptop stand that can rotate, up/down and pivot.
Mounts to available bolts in the Side Board.
Made from the wood (18mm) i had laying around.
The author’s moral rights;
This is a great idea. Thanks for sharing.
David Sease
Hello again. I just cut this project out and the only thing that I see is that the cuts do not properly fit into the cutouts for the mounts. Everything else is spot on.
David Sease
Good day all. I just cut this out and used 3/4" MDF it looks like it is intended for 1/2" just a FYI for anyone wanting to cut one of these for themselves.
Bryan Aitken
Stupid question.... but... what type of hardware is used on the base so it can pivot?
Jeremy Austin
newbie here how do i use someone elses design on here. i
for some reason dont see it
Kathy Wilt
What did you use to make the base pivot?
Seth Bruins
No hardware needed to pivot. Wood against wood.
Mike Phillips
New to CNC which bit is best to cut this? and how long should this take to cut? shortest I can get is 4hr I believe.
Colby Lucier
The circle part of the base that the mounts are on goes in the square base but I can't see what hardware is used through the holes in the center so that it can be stable and rotate.
John Choate
Panos Gerontis
Carl Brink
Hans T
Panos Gerontis
YML
Traxxtar
Hans T
Sam Gironda
Neil A
Brian Hoelscher
David Sease
David Sease
Bryan Aitken
Jeremy Austin
Kathy Wilt
Kathy Wilt
Seth Bruins
Mike Phillips
Colby Lucier
John Choate
Kenny Yates
