Just engraving a world map into a piece of oak wood. I used a 1mm 2 flute end mill. After some sanding the wood was oiled and cut out with a table saw. Thats it ;-)
What software did you use to create the toolpaths?
Paul Kaplan
Hey Paul,
I used CamBam as my CAM Software. Normaly I start with a picture, vectorize it with inkscape and export it as an dxf. Than I use CamBam to adjust the dxf file, because sometimes one big linie is splitted into many short ones. CamBam can fix this. So the job runs faster.
f dchmnn
Paul Kaplan
f dchmnn
