Special Pre-Sale Offer: Up to 41% off the NEW X-Carve Pro
(3 days left for pre-sale offer)
Call us: (312) 775-7009 M-F 9am – 5pm CST
WoodRiver Pocketknife (Item 163955)
4 opens
0 copies
12 downloads 0 comments
Matthew T Mead
Matthew T Mead
Great quick project to make wood sides for this pocketknife using 1/8" hardwood.
African Mahogany Wood
6" × 12" × 1/8" African Mahogany
$5.86
$5.86
File type blank
WoodHandleDesign.svg
SVG for wood handle
Instructions from Woodcraft are good
Instructions from Woodcraft are good and can be found linked from this page: https://www.woodcraft.com/products/side-lock-folder-blade-kit-4-1-2-closed-woodriver
Note that you will need a special micro screw driver that is about 1.5mm.
Note that my design does not include a hole that needs to be drilled. By following the instructions, they instruct how to mark the hole once side pieces are dry fit.
I scuffed up my knife while sanding my wood to fit (per the instructions). I will be hitting the stainless steel on the knife with fine steel wool and that should remove all scratches.
