For a Limited Time: Up to $2,000 off the new X-Carve Pro
Call us: (312) 775-7009
Email: help@inventables.com
Wooden Watch
Sumanth Shekar
Sumanth Shekar
Chicago, USA
Analog watch made with walnut and soft maple
Soft Maple
Soft Maple (×2)
6" × 12" × 1/8" Soft Maple
$6.50
6" × 12" × 1/8" Walnut
$5.57
$12.07
Carving the watch top
Open the Watch Top-1 Easel Project
Setup your Carvey with 1/32nd inch bit and clamp the 1/8 inch walnut sheet. Carve out the part but do not take it out [IMPORTANT]
Next open Watch Top-2 Easel Project# and click carve
Carving the watch back
Open the Watch Back Easel Project and carve out the part with 1/8’’ Walnut:
Carving the links
Open the Watch Chain-Walnut Easel Project
Carve out the links using a 1/32" bit and 1/8" Walnut sheet.
(Optional)Take 1 sheet of Soft Maple and cut in half, then glue the two sheets to each other and let it set over night. This will make the chain a little thicker
Set up the Maple sheet in Carvey and open the Watch Chain-Walnut Easel Project
You will have now carved more than the required number of links, which you may need because the links are delicate and may break.
Carving the watch middle part
Open the Watch Middle Easel Project and carve out with 1/8 inch maple sheet. Measure the sheet carefully and adjust the depth of the pocket so that when assembled the movement’s spindle sticks out.
Tip: Start of with a less deep cut and sand off the face to the required thickness.
Assembly
50 minutes
You will also need the following parts:
Clasp
Watch Crystal Glass 30mm diameter
Movement
Pins
Stick the movement to the Watch Middle using superglue, be careful to apply superglue only to the sides of the movement
Stick the Watch Top and Watch Back using wood glue, you may want to sand them down a little and even polish them to make it look even better
Cut the Pins to about 10mm length and tap them into the links. Press the glass into the Watch Top.
Attach the clasp to the strap with the spring loaded springs provided.
It may seem a little intimidating and tedious, but it the watch will look great when you’re done.
Norbert Vienneau
Love this project. Any chance it could be made public?
Norbert Vienneau
Sumanth Shekar
Thank you Norbert. I would love to share the project with everyone, the project is public.
Sumanth Shekar
Bill Fuqua
I guess I missed the window of this project being open. I would love to give it a shot. bf
Bill Fuqua
Ken  Timblin Sr.
beautiful!!
Ken Timblin Sr.
