2 minutes
The first cut we will make creates the chamfer of the cover. This will be done using the 1/4" 60º V-Bit. It should pass through all but about 1/8" of wood, which will prevent it from being removed until the next step. Once the cut is done, swap the bit for a 1/8" standard wood bit.
Now that you’re wall outlet is carved, we can attach it. Ensure you have switched power off for the outlet before you begin. Remove the current wall cover by unscrewing the flathead screw located between the two outlets, and screw the new cover on.
