Mon - Fri: 9am - 5pm CT
Sun: 12pm - 4pm CT
Support will not be available 9/28-9/29
Wooden Legos
362 opens
100 copies
2 comments
Garrett
Garrett
Michigan
Make your own standard Lego bricks out of any material that you can cut on your X-Carve. Paint or stain them to make them any color you want.
Hard Maple
Hard Maple
6" × 12" × 1/2" Hard Maple
$8.86
$8.86
Lego Dimensions
I wanted to make the Lego pieces actual size so that they can engage with actual Lego pieces. To do this, I needed to find out the what the dimensions of a standard Lego was. I found the dimensions on the following site and then extrapolated on them to make the various sized pieces.
https://grabcad.com/tutorials/lego-01-basic-dimensions-bricks-explained
Create the Pieces in Easel
45 minutes
Now that I had the dimensions it was time to create them in Easel so that they could be cut out. I designed these so that you would cut out half of the piece and then flip the piece over and then cut out the other side of it. This will result in two of each size piece when done cutting both sides.
I left a thin flange around each piece so that the pieces would remain in place while cutting.
Cut out the Pieces
40 minutes
Now just cut out the pieces. It takes about 19 minutes per side.
Have fun with them
500000 minutes
Now you can have have many hours of fun with your new Lego pieces.
Brad Mitchell
Good job! Lots of thought and detail went into this. Thanks Garrett. I had a similar idea but now its time to "lego" of that one since you beat me to it! :)
Brad Mitchell
Garrett
Thank you. Hopefully I saved you some time if you have a cnc router. Or good luck coming up with another project if you're hoping to win one.
Garrett
