Wooden Bookmark to hold your book closed
19 opens
8 copies
486 downloads 1 comment
Brian Wharton
Brian Wharton
Redondo Beach, US
This is a wooden bookmark with an elastic strap that holds your book closed by creating a slot in the bookmark and threading waistband elastic through and sewing in a loop.
AUET01 v20120307-01.vsd
I used Visio first to create my design
bookmark.svg
Here is the visio converted to .svg
Cut out the bookmark
First cut out the bookmark. I made a plain one and then I did another with my companies logo.
What I did is use tabs for the outline of the bookmark. but don’t use tabs for the slot that the elastic goes through.
NOTE: I used 1/8" plywood from a craft store. Inventables has something similar.
Cut the tabs and sand
I did alot of sanding to clean things up. I didnt finish mine. but, I might. If you finish, I would do at least one layer of clear acrylic over so that none of the stain will ruin your book.
Add the Elastic
Next, I took 1.5" waistband elastic to about the size I wanted and thread it through the slot in the bookmark and used my trusty sewing machine to make a loop that will then hold the book closed.
Jeremy Richards
Very nice choice of book to show for an example. :)
Jeremy Richards
