These pumpkins and gourds are assembled like a puzzle. Perfect for fall decor. Cut out of inexpensive 1/4" plywood they make a huge statement once assembled!
The author’s moral rights;
Nice project! Thanks for sharing.
I would suggest that if using 1/4" MDF, move the tabs close to the ends of each "rib". The MDF is flexible enough to be lifted by the bit. This causes the thin end to break.
John Owens
John Owens
Roy Hitt
