Wood Nightstand Catchall
2282 opens
1171 copies
1570 downloads 7 comments
Kat Harris Parker
Kat Harris Parker
Atlanta, Georgia
A wood catchall tray designed to keep miscellaneous items at bay, and within your grasp. The perfect size where space is limited. Whether its in your homes entry table, your desk, or nightstand (Where I keep mine), this tray keeps things organized, & a space to charge your phone at night to boot.
Red Oak
Red Oak
6" × 12" × 1/2" Red Oak
catchall
The nightstand catchall came into creation out of pure necessity. I had one that was made out of some type of acrylic or plastic that discolored over time, and I felt it was time for a new one. I also had a wooden phone dock I made from a piece of walnut years ago that sat on top of my previous catchall, and I thought, “Wouldn’t it be awesome to have one item that encompasses both!” With that thought I opened up my design software of choice and started playing with shapes until I settled on the one I liked. After finalizing the design, I saved the .svg file and imported it into easel.
Note: (The dimension of the Phone slot on the catchall was designed to fit “MY” Smartphone. I have the Samsung S6 Galaxy Edge Plus – if you have a different phone you will have to make adjustments to the phone slot to fit your phone. This can be done easily by simply using a pair of digital calipers to measure the width of the phone. The depth of cut will remain the same.)
Carving
120 minutes
The next step was to choose the wood I would use for the catchall. Although I think it would look awesome made out of Walnut, I choose to recycle the wood from a 70 year old table that I saved from the landfill, so the wood used in this project is Oak.
After securing the material on the machine, I installed the largest bit I had in the router, and set out making my new catchall.
The bit used: High speed steel 2 flute upcut Spiral.
Cut Settings: I utilized the recommend cut settings, however I feel this was entirely too safe and I could have increased the Feed Rate/Depth per pass a tad.
Finishing
After the job was complete, I sanded over the entire piece with 220 grit sand paper, and then applied a homebrew wood conditioner to give it a soft luster and satiny feel.
Don Hatfield
well done! this is a great project, very clever design. you've really got me thinking!
Don Hatfield
Harald Haaland
Very nice! My son and I made one today, as our first project on our brand new X-carve. Turned out (nearly) perfect, after some newbie trial and error!
Harald Haaland
Kat Harris Parker
Congrats on your first project! Post a pic let's see!
Kat Harris Parker
Tim Belton
Do you have the SVG? I can't get the png to convert well
Tim Belton
Kat Harris Parker
Hi Tim, Just open the project in Easel and make your edits there. I did this project so long ago, I can' even remember where the original files are so the easiest way is to just open it up in Easel and make whatever changes you want to make in the program.
Kat Harris Parker
David kehoe
was there any Bit preference here? Bowl Bit?
David kehoe
Kat Harris Parker
Hi David, I made this maybe 4 years ago when I was new to CNC & at the time I had no clue about different bits. I think I used a 3/4 straight bit to hog out most of the material and followed that with a ball nose bit for the details but if I had to make this over, I would definitely use a bowl bit.
Kat Harris Parker
