Wedding Anniversary - Monogram
735 opens
236 copies
1 comment
Steven Vasquez
Steven Vasquez
USA
Bamboo Cutting Boards Monogram
Purchase Cutting Boards
You can buy this 3-Piece cutting board set at any Walmart Store or at these links:
https://www.walmart.com/ip/Freshware-Bamboo-Cutting-Boards-3-Piece-BC-200PK/54493668
https://www.ebay.com/itm/Bamboo-Cutting-and-Serving-Boards-set-of-3/232552539306?hash=item36253624aa:g:FnsAAOSwgZ1XrKkN
Edit Text
In Easel:
- Edit the text of the First name of the married couple.
- Edit the larger text of the Last name of the married couple.
- Edit the the Wedding Date text.
Carve
I carved the larger Last Name text with a 1/32" up-cut bit.
Keeping the same XY Zero, I then switched to a 60° V bit for the finer text and swirl lines.
60°V bit settings I used:
- Bit with 0.010 in
- 50 in/min feed
- Plunge 9 in/min
- Depth per pass 0.01 in
Alternatively you can use the default V bit settings from Easel PRO.
Other
Visit my website: L4MakerShop.com
Purchase decals and other items form my Etsy store:
https://www.etsy.com/shop/L4MakerShop/
Harrell Rawlins
Took your design and added a twist on it.
Harrell Rawlins
