The author’s moral rights;
I used a .01 engraving bit. The one with the orange ring on it. This was for the finish cut. I think I used an .125 end mill for roughing it in. It took forever to finish because of the finish bit size but I wanted the detail.
Creighton Hughes
Can you post the roughing pass aswell in this project? 7/30/18
Andrew Petzold
I think I found the correct roughing and finish files to upload. Try them and let me know.
Creighton Hughes
Andrew Petzold
Creighton Hughes
Andrew Petzold
Creighton Hughes
