This cut will cut out two mind puzzle games. A Tangram Triangle which can make many designs and shapes you can challenge yourself with and a game called Bridgeit where you tic tac toe but with bridges going across the board. Think Connect four and tic tac toe.
The author’s moral rights;
Chris Fonseca
Dallas Brown
Chad Rees
