Tracksaw Rail Wall Mount
45 opens
16 copies
1 comment
Scott C Young
Scott C Young
5 horizontal rail mounts for Festool, Powertec and Makita rails
- 3 for long or joined rails
- 2 for the standard 55" rail
Additional Tools/Materials Needed:
- 1/8" dble flute bit
- 12″ × 18″, 1/2" Baltic Birch Plywood
- 3/8" Dowels for alignment posts
- 1-1/4" Wood Screws
- Glue
12" × 24" × 3/8" Baltic Birch Plywood
$5.99
$5.99
Build Guide
1. Top of assembly includes the component with the arrow, a small 2-hole component and a large 4-hole component.
2. Combine the 4-hole and the small 2-hole parts together with dowels and glue. Then trim and sand flush.
3. Place the arrow component on top and pre-drill through the smaller 2-hole part using a 3/32 bit. Place a wood screw through the parts, careful not to over tighten.
4. Repeat assembly for the lower structure, using glue, one small 2-hole part and one medium 2 hole part and the bottom of the large 4-hole component. For these, the dowel will go all the way through all 3
