Tool Storage
Gaëtan Mahon
Gaëtan Mahon
Basel, Switzerland
Making use of the center mounting place on the extension board I decided to make a Tool Storage Area for clamps, collets, 1/4 & 1/8 bits and the collet spanner.
MDF Wood
MDF Wood
01 1-8 Combined.nc
Part 1/3 - 1/8 2F Straight Bit
02 90° Combined.nc
Part 2/3 - 90° Counter Sink
03 1-8 Single.nc
Part 3/3 - 1/8 2F Straight Bit
Step 1 - Important Notice
2 minutes
Important notice!:
  • Feeds ( 1’950mm/min ) and Speeds ( DeWALT 16’000rpm ) have been tested on a Y-Axis stiffened X-Carve V2 running UGS.
  • While the Bill of Materials lists an 8 × 12 × 1/2 MDF this Project actually requires a 220mm x 370mm x 8mm one.
  • The Files include the G28 ( YOUR parking position ) and M5 Commands ( turns off Spindle at the end of a file )
Step 1 – Mounting the Work Piece:
The Stock Origin is in the center of the Stock and it’s top surface – For all Files.
Measure 110mm from the left/right and 185mm from the top/bottom to get the center of it and Zero the Work Piece to all three Axis by also Probing it – On the X & Y-Axis this would leave you with a 10mm boundary for clamps.
Once set you’ll be fine for the entire procedure only required to reProbe after each Tool Change.
Step 2 - Bits and Duration
Step 2 – Bits and Duration:
File 01 will use a 1/8 2F Straight ( black ring ) bit and will require about 20-25min to mill.
File 02 will use a 90° Counter Sink bit and will require about 3min to mill.
File 03 will use a 1/8 2F Straight ( black ring ) bit and will require about 3-5min to mill.
Step 3 - Assembly
3 minutes
Step 3 – Some assembly required:
Mount the Tool Plate to the Side Board using 4x M5x15mm screws and matching standoffs.
I used metal M5x15mm ones but you could make your own out of MDF and use longer M5x30-40mm screws.
Joseph Herrmann
how did you go about running the .nc file on your x carve?
Joseph Herrmann
Gaëtan Mahon
Using UGS-P ( https://github.com/winder/Universal-G-Code-Sender )
Gaëtan Mahon
