Timber Keycaps Cherry Stem
19 opens
7 copies
300 downloads 0 comments
Wenray Wang
Wenray Wang
Sydney, Australia
Been wanting to make some of these for a while, and thought quarantine would be a good time to tick some projects off. This was inspired by one of the titanium RAMA keycaps, what you could say is a poor man’s version of it.
Keycaps.dxf
Keycap DXF with reference holes
Order of cuts
40 minutes
Timber stock I was using was a 19mm thick piece of blackbutt, stock size required for this project is 120mm x 30mm but feel free to view and edit yourself in fusion360 using this link: https://a360.co/2y2AOnj
Cut 1 was done with a 1/4 inch straight bit (2 flutes) which cut the bulk of the material and two reference holes which I used dowels in when I flipped the piece (the reference holes were carved into the wasteboard so I did not need to zero once I flipped the timber)
Cut 2: 1/8 inch straight bit (2 flute)
Cut 3: 1mm straight bit (1 flute)
Cut 4 (reference into wasteboard): 1/4 inch straight bit 2 flutes. Dowels used for the referencing were 1/2 inch I believe
Reverse side cut 1: 1/8 inch straight bit 2 flute
Reverse side cut 2: 1mm straight bit 1 flute. Definitely need the finer bit for this pass to allow the stem to fit
