Mon - Fri: 9am - 5pm CT
Sunday: 12pm - 4pm CT
Support: 312-775-7009
The Scan-O-Tron 3000 Full Body 3D Scanner
Fred Kahl
Fred Kahl
Brooklyn, USA
This bill of materials covers the Maker Slide and hardware necessary to create the vertical rail for 3D scanning as detailed on the project’s Thingiverse Page: http://www.thingiverse.com/thing:127968
3D printed parts and additional hardware are needed to complete the project.
Aluminum Extrusion (20mm x 20mm) - Clear
Aluminum Extrusion (20mm x 20mm) - Clear (×2)
Height: 20 mm, Length: 500 mm, Width: 20 mm
$9.98
Aluminum Extrusion (20mm x 40mm) - Clear
Aluminum Extrusion (20mm x 40mm) - Clear (×2)
Length: 1800 mm
Length: 500 mm
$10.12
Aluminum Spacers - #12, 5M
$2.99
Button Head Cap Screw
Button Head Cap Screw (×4)
$11.96
Length: 12mm, Quantity: 10, Thread Size: M5
Dual Bearing V-Wheel Kit
Dual Bearing V-Wheel Kit (×4)
V-Wheel - 25202-01, Sealed Bearing - 5mm x 16mm x 5mm - 25196-01 (x2), Precision Shim Washer - 25201-01
Eccentric Spacer
Eccentric Spacer (×2)
Spacer Type: Standard, Qty: 1 don't use, Length: 0.25 in
Extrusion Bracket (Gusset)
Extrusion Bracket (Gusset) (×20)
Finish: Clear Anodized - don't use, Quantity: 1
Flat Washer
Flat Washer
$2.99
Hex Nuts
Hex Nuts
Length: 1000mm - 2012 - 2019
Length: 1800mm - 2012 - 2019
Mending Bracket
Mending Bracket (×2)
Length: 2.0 in, Width: 0.5 in, Type: Bracket, Bracket Type: Mending
Post-Assembly T-Slot Nuts
Post-Assembly T-Slot Nuts (×2)
Thread Size: M5 (5mm) × 0.8, Qty: 10 pack
$20.98
Pre-Assembly T-Slot Nuts Packs of 10 each (×3)
$15.00
$3.99
Standard Wheel Carriage Plate
Type: Plate
$4.49
$82.50
Just a few of the 3D scans created with the Scan-O-Tron 3000
3D Print Parts are on the Project Homepage
The master project page is at http://www.thingiverse.com/thing:127968 and build instructions are also listed as a Make Magazine project here: http://makezine.com/projects/guide-to-3d-printing-2014/scan-o-tron-3000/
The current 3D printable models can be downloaded from Thingiverse. I print my parts 100% solid. You will need 2 makerslide endcaps.
You will also want to build a Heavy Duty Lazy Susan for Full Body Scanning. This is the platform the scanning subject will ride on while being scanned. The instructions for this part may be found here: http://www.thingiverse.com/thing:28454 See the Make Magazine build instructions here: http://makezine.com/projects/guide-to-3d-printing-2014/heavy-duty-turntable/
Assemble Carriage Hinge 3D Printed Parts
Assemble the two 3D printed parts of the carriage hinge- I used a piece of 3mm filament as the pin and melted the tips of it to prevent it coming loose. Glue the Kinect mount on the end of the large carriage hinge.
Glue together the two parts of the guillotine drop piece and so it can be placed on the carriage hinge.
Mount Hinge on the Carriage Plate
Drill the back of the smaller hinge part and bolt it to the Makerslide carriage plate
Cut Makerslide and Aluminum Extrusion Pieces
Makerslide- cut the 1000mm piece down to 600mm
40x 20 Aluminum Extrusion
3 × 500mm sections (for base)
4 × 200mm sections for crossbars
Assemble the Frame
• Splice the 600mm and 1800mm section of Maker Slide together (600mm side will be on the bottom).
• Fashion a base with the 3 lengths of 500mm aluminum extrusions, using the Extrusion Brackets to hold them together.
• Connect the long Maker Slide section to an 1800mm section of Aluminum Extrusion, using the 4 200mm segments and Extrusion Brackets to hold them together.
• Attach the vertical section to the base using the Extrusion Brackets.
• Use the 2 500mm 20×20mm lengths of extrusion as diagonal supports between the base and vertical Makerslide, attaching them with Extrusion Brackets.
Assemble the Scanning Carriage
Finish the carriage using the Dual Bearing V wheel wheels, Aluminum Spacers, Eccentric Spacers, 25mm Socket Head Cap Screws, Washers and Nuts. Tie a string to the carriage top and mount it on the Maker Slide.
Reel Assembly
Put skateboard bearings into the 3D printed Rod Bearing 1 and 2 parts, then mount them onto the extrusion at about waist height. Put the threaded rod through and bolt the filament reel in place.
Assemble filament spool with the “bearing discs”, so it will mount on the threaded rod. Use Washers and nuts to keep it in position. Cut off excess threaded rod. Attach a cabinet knob to the filament reel as a handle for turning it.
Put the 3D printed endcaps on the tops of the rig and then put clothesline pulleys in them(I got mine from Home Depot: http://www.homedepot.com/p/Everbilt-2-1-2-in-White-Clothesline-Pulley-14062/202305414#.Uf8EPWn724R). Thread the string over the top of the rig and back down to the filament spool.
Final Prep
Place the Guillotine drop piece on the carriage hinge, then put several rubber bands around the two sides of the hinges and mount the Kinect onto the carriage hinge. You are now ready to begin scanning.
Samantha Alaimo
Awesome!!
Samantha Alaimo
Alexandre Cruz
If you turn off the controls will the scanner be in the same place or will it fall?
Alexandre Cruz
Fred Kahl
The scanner is manually controlled by cranking the knob on the filament spool to wind/unsond the string. When I am done with a scan, I simply loop the string around the knob to hold its position and prevent the scanner from falling. Hope this helps. fred
Fred Kahl
Fred Kahl
I looked at automating the scanner movements by making controlled by an arduino/servo motor, but the complexity of the scanning subject's geometry changes and its really best to manually scan looking at the scanning software for feeback for what speed of movement should be taken.
Fred Kahl
Mike
Hi there, I've been following and keeping an eye on this for some time now. Glad to say I have all of the pieces needed to complete the set up. Question for you, what settings are you currently using with reconstructme.see they now have a selfie section? Wondering if you wouldn't mind sharing.
Mike
