Introducing the NEW X-Carve. Ships same business day!
Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
The LOOP By MINIMAL
Samantha Alaimo
Samantha Alaimo from Inventables
Chicago
Named The LOOP, a common reference to anyone familiar with Chicago, the MINIMAL design team was inspired by the city and its trains that frequently rumble past their West Loop studio.
Black Acrylic Sheet
Black Acrylic Sheet
Dimensions: 18 in × 24 in, Thickness: 1/8 in
$19.99
Flexible LED Strip - Cool White
Length: 5m, Includes: LED strip, connector wire, power supply, LED Count: 600
Light Diffuser Film Rolls
Dimensions: 12 in × 36 in, Thickness: .007 in, Surface: Matte on both sides
Matte Black Acrylic Sheet
$49.51
Walnut Wood Veneer
Walnut Wood Veneer
Dimensions: 3.74 in × 33.5 in, Thickness: .02 in, Style: paper backed with adhesive
$69.50
File type blank
loop-diffuser.svg
The light diffuser film for 1 lamp
File type blank
Loop-sidepanels.svg
The inside and side panels for 1 lamp
File type blank
Loop-endplates.svg
the outside endplate for 1 lamp
Prepare the Front Panel
Line up the inside endplate panel to the shiny side on the outside end plate. Put a drop of weld on inside the slots and around the inside of the inside endplate.
Line up the inside rectangle to the inside edge of the end plate, to make a slot. Hold the rectangle in place and use weld on around the inside edge.
Prepare the Back Panel
Place the string of LED Lights with the
Prepare the light diffuser
Bend all of the tabs on the light diffuser film at a right angle
Attach the light diffuser film
Place the longer piece of light diffuser film inside the track of one of the end plates, with the tabs facing away from the center cutout. Clip in the corner brackets to secure the film. Then clip in the flat springs so the film has a snug fit around the inside cutout.
Then place the shorter piece of light diffuser film around the rest
Matt McCoy
Great!
Matt McCoy
Faizan Shaik Mohammed
What material did you use to cover the diffuser film, the brown part I mean. What material is it. ??
Samantha Alaimo
It is walnut wood veneer: https://www.inventables.com/technologies/walnut-wood-veneer
Samantha Alaimo
Patrick Dinnen
Love this design but it looks like the instructions got cut short. Step 4 is the last one I see. Am I missing something?
Patrick Dinnen
Alex Heijnen
Yeah, same as the comment above. Would like to make this lamp, but the instruction seem incomplete!
Alex Heijnen
Sadia Khan
Can someone please fill in step 3 & 4 as it is incomplete and I would love to make this for my office :) Thanks so much!
Sadia Khan
