Sign for team snowcat
check out his videos here https://www.youtube.com/user/snowcatxx87
He talks about this sign here https://youtu.be/ER-zeNvcS-Y?t=4m50s
No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
2 foot by 11 inch sign made from poplar .50 thick
used 60* V bit and a 1/16 end mill.
round over on sided
airbrushed paint and sanded to 320 grit
3 coats of a high gloss finish
back side shows my Facebook page and Instagram
