Teak Wood Light with Resin Inlay
105 opens
44 copies
3 comments
Aaron Fried
Aaron Fried
Florida
Cut the design most of the way through the wood then poured table top epoxy with blue dye to fill the design. Sanded top and bottom. Build a box, insert a light, and you have a wooden light! Watch the video here! https://youtu.be/7mWHd2yEIKk
Carve a design in the wood, cutting almost all the way through.
120 minutes
You can really do any design you want. The key is to not cut all the way through the wood so that the epoxy fills up the holes. If a section does cut all the way through, it’s ok, just cover the back with masking tape. All kinds of wood work too, I haven’t used plywood because I wouldn’t want to sand through the layers. I’m sure with some precision it can be done though.
Mix Clear table-top epoxy
4 minutes
There’s a few different brands out there. If you haven’t mixed epoxy before be sure to mix THOROUGHLY! If it doesn’t get mixed all the way it’ll never dry.
Add colored dye to epoxy
I added polyester dye, but all types of colorant will work. If you’re not sure, try it out with a sample. Some colors are opaque and won’t work.
Pour epoxy into your design
Pour the epoxy into your design and squidgy the excess off. Come back tomorrow for sanding.
Sand or plane front and back
Sand or plane the front and back to remove the wood on the bottom and any epoxy on the top.
Make a frame and add a light source
If you want you can do 4 designs and have 4 sides light up. There are so many possibilities. Use your imagination. The video of this light from start to finish can be seen here.
Aaron Fried
You can see the video from start to finish on my YouTube channel here https://youtu.be/7mWHd2yEIKk
Aaron Fried
Ryan Parish
How much Epoxy did you use for this? Is there a brand you prefer? Much of what I've found is somewhat cost prohibitive! Awesome project!!
Ryan Parish
Aaron Fried
I used less than a quart. There's a fiberglass place close to me, 2 gallons costs about $80. Home depot sells what I remember being a half gallon kit for $20, I may be wrong.
Aaron Fried
