480 minutes
Rough Pass – 1/8" End Mill
Feed Rate: 46.8 in/min
Plunge Rate: 9 in/min
Depth Per Pass: 0.0625 in
Detail Bit – 60 Degree V-Bit
Feed Rate: 52 in/min
Flip piece and add Key Holes in Back
Use Key Hole Bit: 3/8" Diameter
3 coats on front prior to painting:
I use the following:
Minwax – Waterbased – Polycrylic – Clear Satin
(30 minutes between coats)
Route outer edge with 1/4" round over bit
Peal off Oramask (using small Exacto knife if needed.)
Sand exposed wood front and back
Using 220 grit
Blow off dust
Wipe down with damp micro-fiber rag
3 coats front and back
Let dry and you are done!
Glenn Watson
