Carefully remove backing while applying mask to board. Be sure board is perfectly clean and smooth before starting. Smooth the vinyl as applied and rub into place with a roller. Align board on CNC and run the frame code.
Run The Field Code
40 minutes
Field is cut with a 1/2" 90° V-carve bit.
Complete The Project
Spray color of your choice to cover the entire project. When set, remove the mask to reveal your result.
