SAVE BIG DURING BLACK FRIDAY! NOW THROUGH NOV. 28
Superman Logos
179 opens
98 copies
Donald LeBlanc
Donald LeBlanc
Eastvale, California
We recently had my son’s birthday party and he wanted a Superman theme so I decided to make some Superman logos. 5 smaller ones to give out as prizes and 1 big one to hang in his room.
Birch Plywood
Birch Plywood (×2)
Purchase 1/4" plywood
I checked the prices at my local Lowes and it was around $8 for a 2′ × 2′ × 1/4" plywood panel and you need 2 of them for this project. I checked the full sheet plywood area and found a 4′ × 8′ × 1/4" sheet for just under $16. I had them cut the sheet down the middle on the 4’ length, then stack the 2 pieces together, and cut those in half. This left me with 4 – 2′ × 4′ pieces. I took those home and cut them in half so that I ended up with 8 – 2′ × 2′ panels.
Format the Superman logo file
I have an X-Carve CNC machine. I found a black and white Superman logo on the web and imported it into Easel. I resized the logo to make 5 – 6″ × 8″ logos and 1 – 16.5″ × 22″ logo. Make sure to rotate the logos to make them upside down and don’t just flip them on the horizontal axis. I made 2 copies. 1 with the “S” cutout and 1 without.
Cutout the pieces
90 minutes
I cutout all the smaller “S” logos first followed by the large one last. I then cutout all the backer shield pieces in the same manner.
Paint the pieces
Once everything was cutout I took the backer shield pieces outside and spray painted them a bright yellow. The paint had a little trouble sticking to the plywood so I sprayed the “S” pieces with a flat black and let it dry for an hour or so. I then followed that with a coat of bright red.
Glue everything together
Once everything is completely dry use a hot glue gun to attach the top red piece to the bottom yellow shield
