1 open
1 copy
84 downloads 0 comments
Kookie Snatcha
Kookie Snatcha
My remake of the fidget spinner challenge. I did full 3D machining on both sides.
In case anyone wants to make one of these I included the GCODE files I generated with Vectric Aspire so you can download and import them into Easel for carving.
Two-Color HDPE - Black on White
Thickness: 1/4 in, Dimensions: 8 in × 12 in, Quantity: 1
$4.99
Two-Color HDPE - Red on White
Thickness: 1/4 in, Dimensions: 12 in × 12 in, Quantity: 1
$7.49
$12.48
File-type-blank
1_AlignmentHolesDrill.nc
This is the first step. I used a 1/4" drill bit.
File-type-blank
2_OutsideCut.nc
Second step, I used a 1/8" single flute up cut end mill.
File-type-blank
3_BearingHoleCut.nc
Third step, I used a 1/8" single flute up cut end mill again.
File-type-blank
3.5_3D_Finish_TOP.nc
Fourth step, I used a 1/8" ball nose end mill for this.
File-type-blank
4_3D_Finish_BOTTOM.nc
Final step, the part gets flipped over and realigned using the alignment holes for this. I used a 1/8" ball nose end mill again for this step.
