Star Wars Silhouette Figures
467 opens
203 copies
1075 downloads 2 comments
Garin Gardiner
Garin Gardiner
Tigard, USA
My son wanted to decorate his room with Star Wars goodies so we cut out a few silhouette figures to hang above his closet door. We found a few images to trace as vector art and saved them as SVG files we could import into Easel to cut out. It’s an easy project once you have the design files
Cutting Diameter: 1/8 in - 2013 - 2016, Shank Diameter: 1/8 in, Quantity: 10
White ABS Plastic Sheet
White ABS Plastic Sheet (×3)
Dimensions: 8 in × 12 in don't use, Thickness: 0.25 in don't use
Sand.svg
Sandcrawler
C3P0.svg
C3P0
speeder.svg
Speeder
tauntaun2.svg
TaunTaun
ATAT5.svg
ATAT
R2.svg
R2D2
Getting Started
I have provided the Easel project you can open and use as well as SVG files you can import into your own project. Since there isn’t a way to provide multiple Easel projects, I have made the material 3X longer so I could include all shapes in one project.
Open the Easel project and arrange the the shapes you want to cut out. Determine the material thickness you are using and make sure the depth is correct on each opject
Set up Machine
Put your sheet in your machine and clamp it down. I have used glue, tape and clamps but have found my favorite way to hold down my material is with the Work piece hold down that Warren posted a bit ago.
Cut Out Shapes
With your material properly held down, select “Carve” and let er rip!!!
Remove Shapes
Remove the ABS sheet from your machine and cut the tabs to pop out each of the shapes. if necessary sand off burs from where the tabs were.
Stick Em Up
I grabbed some 3M Tape and just put a piece or two on each shape and pressed them to the wall firmly.
Sit back and relive the glory days of Star Wars!!!
Mike Machado
What feeds/speeds did you use?
Mike Machado
Arne Friedrich
Simple project perfect done. NICE !!!
Arne Friedrich
