Stacking Boxes
125 opens
18 copies
Beyond Design
Beyond Design
Chicago, Illinois
Simple square boxes designed to minimize material waste and cut time. In this instance of the design I made one set from HDPE and expanded PVC. The other set is HDPE with cork and acrylic.
40% Light Transmission White Acrylic Sheet
Black HDPE Sheet
Black HDPE Sheet
Thickness: 3/4 in, Dimensions: 8 in × 12 in
Grey Expanded PVC Sheet
8" × 12" × 1/8" Grey Expanded PVC Sheet(Do not use)
Natural Cork Sheet
Natural Cork Sheet
Dimensions: 8 in × 12 in, Species: Cork, Type: Sheet, Thickness: 1/8 in
Mill box walls
Use a 1/8" square or fishtail endmill to mill the walls for the box set. A 3/4" or taller material will be best for making a functional box. Use double sided tape to keep the nesting sections from shifting
Use this EASEL link
Mill box lids
Choose a 1/8" material to use as your lid. Expanded PVC cuts quickly and comes in good colors. A translucent acrylic also works really well.
Use this EASEL link
Mill box bases
Mill the box floors from either the same material as the top, or choose one that compliments it well.
Use this EASEL link
Assembly
If everything cuts correctly, no glue is required for assembly. The base fits into the side with the small ledge cut into it. For extra durability you can squeeze a small amount of super glue into this area.
