Special Offer: Up to 17% off the new X-Carve Pro
Hurry! Offer ends on 05/28 (20 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Speak Your Mind
Samantha Alaimo
Samantha Alaimo from Inventables
Chicago
Speak Your Mind allows you to always tell passerby’s your thoughts with out having to tell them directly! It can also double as a coaster or trivet!
Natural Cork Sheet
Natural Cork Sheet
Dimensions: 12 in × 12 in, Type: Sheet, Species: Cork, Thickness: 1/4 in
Cut down the stock material
Cut the cork sheet into a 12×5 sheet. You need to cut the sheet size down to better secure it to the machine bed.
Double sided tape
cover the entire back side of the cork with double sided tape. The tape is what we ail use to secure the cork to the material bed, so it is very important to tape the entire back side.
Secure cork to the base
Press the double sided tape down to the material bed. Make sure the material is safely secured.
Program and run the file
I used a Makercam.com to program and a gcode sender run a shapeoko machine. The settings I used are included in the video below! You can use other programs and machines as well. This file will also work for laser cutting.
Use as you please
You can now use your Speak Your Mind cork as a message board, coaster, or trivet!
Krishna
Hi There, It's great to utilize the power of internet <a href="https://asha24.com/informatica-pim-training"> with the available free blogs. </a> Appreciate your effort for making such useful blogs and helping the community. Regards, Krishna
Krishna
