Small Gecko Cut out
13 opens
8 copies
463 downloads 0 comments
WorkinWoods
WorkinWoods
Hello everyone this is a small project that I made of a small gecko finish to your desired liking be sure to let me know how you did it
Birch Plywood
Birch Plywood
Image of small Gecko
small gecko.nc
Easel Gcode for Small Gecko
small gecko_roughing.nc
Easel made Roughing Gcode .125" bit
small gecko_detail.nc
Easel made Detail Gcode .03125" bit
Setup and Carve
Easel setup:
Roughing Pass
Saftey Height: .150"
Step over: 40%
Feedrate: 45 in/min
Depth of cut per pass: .0625"
Depth of total cut: .050"
material thickness: .25"
Material type: Birch Plywood
Bit Size: .125"
Detail Pass:
Step over: 40%
Feedrate: 15 in/min
Depth of cut per pass: .015625
Bit Size: .03125"
It would save alot of time if you do a roughing pass with an .125" bit and then go back and do a detail pass with a .03125" bit I will provide a roughing Gcode file and Detail Gcode file above make sure and have this feature turned on in easel by asking for access in this thread on the Inventables forum with the link below
https://discuss.inventables.com/t/two-stage-cuts/869/582
