Simple Corner Jig
Nic Shimala
Nic Shimala
Houston, USA
This is a very quick and simple jig or consistent 90 degree. Through holes for the bolts are fitted for the M5 hold down bolts. There is a flat washer recessed so the bolt has a solid surface that will last as well as not wear out the wood.
MDF Wood
MDF Wood
Dimensions: 12 in × 12 in, Thickness: 1/2 in
Juan Carlos Santamaria
Hi Nic, this is a great jig. Would you share your Easel project? Thanks!
Nic Shimala
i honestly thought I uploaded it. I'll try again.
Nic Shimala
Nic Shimala
I can't seem to find how to add the Easel file to the project, so here's the link. Hope this works. http://easel.inventables.com/projects/qqUvLN4dPwPdwQlk1lWUUg
Nic Shimala
It works! Thanks Nic!!
James Crowley
Would love this file!
James Crowley
Elpha Yule
How do i get the file
Elpha Yule
Chris Clinton
Nic, can you share again?
Chris Clinton
