Support closed Sunday 4/2
Shapeoko 2 - The Works 220V
Zach Kaplan
Zach Kaplan from Inventables
Chicago, USA
This package includes the Full Kit + Upgrades. It includes a Quiet Cut spindle, a waste board with clamps, and an electronics enclosure.
This setup is recommended if your goal is to make stuff with the machine. This kit is ideal for businesses, Etsy Sellers, makerspaces, libraries, and schools.
24v Fan
24v Fan
Voltage: 24 VDC, CFM: 19.8, Size: 60mm × 60m × 25mm, Category: Accessory
Aluminum Extrusion (20mm x 20mm) - Clear
Height: 20 mm, Length: 500 mm, Width: 20 mm
$4.99
Aluminum Spacers - #12, 5M
Length: 0.3750 in - 25312-05, Inside Dia.: .192 (4.9mm) - 25312-05, Outside Dia.: .3125 (7.95mm) - 25312-05
Black Expandable Sleeving
Black Expandable Sleeving (×3)
Type: Expandable Sleeving, Color: Black, Range: 1/8 in - 7/16 in, Size: 1/4 in
$4.47
Black Heat Shrink Tubing
Black Heat Shrink Tubing (×3)
Type: Heat Shrink Tubing, Size: 1/4 in, Ratio: 2:1, Color: Black
$4.47
Button Head Cap Screw
Length: 12mm, Quantity: 10, Thread Size: M5
Full kit - 220V, includes electronics and tool set
$695.00
Drag Chain
Drag Chain
Type: Drag Chain - 2014 - 2019, Qty: 1m, Link Type: Semi Open
Drag Chain
Drag Chain
Type: Drag Chain Ends - 2014 - 2019, Qty: 2, Link Type: Semi Open
E-Stop Button
E-Stop Button
Type: Latching pushbutton
Enclosed Power Supply
Output Voltage: 48VDC - 2014 - 2017, Current: 7.29A, Power: 350W
ER11-A Collets and Nuts
ER11 Collet Wrench Set
Extrusion Bracket (Single Slot)
Extrusion Bracket (Single Slot) (×3)
Finish: Black Anodized
Flat Washer
Flat Washer
$2.99
gShield Enclosure
gShield Enclosure
Color: Black Anodized Base & Cover
Hex Nuts
Hex Nuts
Knurled Aluminum Knob
With crank
Thread Size: M5 (5mm) × 0.8
$5.00
Quiet Cut Spindle
Quiet Cut Spindle
Power: 300W, Voltage: 48VDC
Sanding Sponge
Sanding Sponge
Fine/Medium Sanding Sponge
Length: 30mm - 2012 - 2018, Quantity: 10, Thread Size: M3
$3.99
Spindle Speed Controller
DC Spindle Speed Controller
$35.00
Terminal Block
Terminal Block
Positions: Terminal Block 4
$4.99
Waste Board with Threaded Inserts
Size (approx): 500mm 500mm 1/2" MDF, Inserts: M5 Qty 36
Wood Clamp Set
Wood Clamp Set
Type: Clamping System 1, Qty: 4 - don't use
Zip Wire
Zip Wire (×7)
Gauge: 18AWG, Length: 1 ft
$760.90
Patrick Grantland
This picture looks bigger than the cutting area of the full kit (300mm x 300mm x 50mm). Under the bill of materials the size of the waste board is listed 500mm x 500mm. Is it possible the CNC machine pictured is using the 1000mm by 1000mm rails?
Patrick Grantland
Chanchai Chayasombat
1) I have ordered Shaperoko-3 last month. 2) Due to urgently needed, will it be possible to cancel that order and buy Shaperoko-2(the works 220v.) with upgrade to 1000x1000 mm. now Tks, Chanchai (Bangkok,Thailand).
